377Views5Replies
Author Options:
Broken Power Inverter Answered
I have a sima 140 Watt power inverter, and it doesn't work anymore! I don't know why... I don't have much experience with inverters. Can someone help?
framistan
framistan
Best Answer 10 years ago
If the battery voltage is LOW... then the inverter will not kick on. If you overload the inverter with too much stuff ... it might burn out. If the terminals connecting the unit to the power source have corroded connections it will not work. Dont overlook the negative ground connection for looseness or corrosion. Fuses sometimes LOOK ok ... but test bad with a meter. Always test fuses with a METER, not your eyeball.
martzsam
martzsam
Answer 10 years ago
You are right, the fuse looked okay, but I checked it with a meter and it didn't work. Thanks!
martzsam
martzsam
Answer 10 years ago
I checked the fuse and that seems to be the problem. Thanks!
martzsam
martzsam
Answer 10 years ago
Well im pretty sure its plugged in... I'm not that stupid. :-P
I should have thought of the fuse though. Brain fart on my part.
