1955Views9Replies
Author Options:
Brushless motor upgrade for exceed?? Answered
I have an exceed sunfire buggy 1/10th and I am planning on getting a brushless upgrade. I don't know if the battery and car itself can handle the one i want. I have a 7.2v 4200mahNiMh battery pack and the motor I  want to get is a 5.5T 6000kv motor. I was wondering if anyone knew if my car could handle that. If it couldn't, would a 8.5T 4000kv motor be better? And how fast would the second motor go? Please comment soon if you know anything about these motors.
Sandisk1duo
Sandisk1duo
Best Answer 11 years ago
I think the motors have different limits
the 4000kv has more torque
the 6000kv has more rmps
it depends on the gearing of your car, the aerodynamics of it, and other factors
It think your battery can handle it
Electroinnovation
Electroinnovation
Answer 11 years ago
Yes I already dd the calculations
4000 takes up to 9.6 volts and more torque
6000 takes up to 7.2 volds and more speed.
I did the calculations and figured the 6000 goes 45mph and the other goes about 35 mph.
I already did all the calculations what I'm asking is if you thing my battery and the car itself like the gears could handle it.
Sandisk1duo
Sandisk1duo
Answer 11 years ago
don't worry about the battery, it can handle it
if the gears are stock, then i don't see a problem
Electroinnovation
Electroinnovation
Answer 11 years ago
Okay thanks just one more question
What do the timings do? Like how you can program the esc and ther'sdifferent timings like 0.0 and 2.5 all the way up to i think 15.0?
Sandisk1duo
Sandisk1duo
Answer 11 years ago
i have no idea about timings...
The nerdling
The nerdling
8 years ago
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=10330
should get this
Re-design
Re-design
11 years ago
Either one of these should work just fine.  Less run time probably than what you have now but maybe not much less.
What you will have is more control problems because these are probably alot more powerful than what you have now and the wheels are going to break loose easier.
Re-design
Re-design
Answer 11 years ago
You'll probably have to replace the esc.  I don't think the stock one is up to handling the extra power.
Electroinnovation
Electroinnovation
Answer 11 years ago
I'm buying a package from nitrorcx.com for $100 which includes the brushless motor, the brushless 60A esc, and a program card.
What I need to know is if the battery and car's gears and stuff can handle the 6000kv or if I should stick with the 4000kv.
