17438Views56Replies
Author Options:
Build a Small Tesla Coil Answered
I need you help bright minds of Instructables!
I want to make a very small Tesla coil and I have the right schematic! But I still remain a n00b in electronics...
This schematic is used in:
Help me build the schematic below... I would be very grateful to one who makes the schemactic in Eagle or other program that shows everything connected together.
Thanks you very much!
Stanislav A.K.A. Comodore
mino nano
mino nano
9 years ago
hi i'me new hear i realy whant to make a small inexspensive tesla coil out of household items
please can somebody help me
with simple plans
theVader75
theVader75
9 years ago
can you give the schematic for nano tess II and III please
Xellers
Xellers
11 years ago
If you can't get the parts for this, then try Steve Ward's micro SSTC. I built one from a computer power supply and some free samples (The 555 timer and UCC37322 Driver)!
thermoelectric
thermoelectric
12 years ago
I will try to make the schematic in Eagle....
thermoelectric
thermoelectric
Answer 12 years ago
This should be it
I hope I didn't miss any connections
PS the VSS and VDD are the power for the IC and the connections for the power.....
comodore
comodore
Answer 12 years ago
Yay! Thanks! I think I can make everything out here... What value is VSS and VDD??? Thanks!
thermoelectric
thermoelectric
Answer 12 years ago
VDD= Positive
VSS= Negative
Those values you might use again so here's a link
comodore
comodore
Answer 12 years ago
ooo OK Thanks!
thermoelectric
thermoelectric
Answer 12 years ago
You're welcome, Be sure to tell me (and Plas) if it works...
comodore
comodore
Answer 12 years ago
Will do, but still, I can't find all the components I need to realize this project... :(
comodore
comodore
Answer 12 years ago
Do you know any on-line electronic store that ships to Europe?
thermoelectric
thermoelectric
Answer 12 years ago
Possibly Farnell, Plasmana gets his parts from them and he's in the United Kingdom...
comodore
comodore
Answer 12 years ago
Yea, I know that site and they don't have those diodes... I checked.... Thanks!
thermoelectric
thermoelectric
Answer 12 years ago
Oh, Just search them i\on Google, You will most likely get a supplier of them.
comodore
comodore
Answer 12 years ago
Yea, good idea, will do that! Thanks!
rippinblaise
rippinblaise
Answer 12 years ago
do you have the eagle file, not the jpg? if you do, pm me.
thermoelectric
thermoelectric
Answer 12 years ago
Willyou be using the Eagle file to make a PCB out of? If you are, some of the parts aren't real.... (The driver IC, I had to just put a line where the enable pin should have been because I couldn't find that chip in the Eagle library. )
rippinblaise
rippinblaise
Answer 12 years ago
that is what i was going to use it for you could download the library it's in or i could i guess can i have the file though?
thermoelectric
thermoelectric
Answer 12 years ago
I'll give you the file but the thing with the enable pin won't work on a board because it is not the right part...
comodore
comodore
Answer 12 years ago
Thanks, I am very thankful! Thank you so much!
Goodhart
Goodhart
12 years ago
Are 2 interrupters involved, or just one attached at the enable pin?
comodore
comodore
Answer 12 years ago
I am really not shore, my guess is 1.
miiwii3
miiwii3
12 years ago
look I'm an electronic genius i can build anything electrical but this is a little difficut. you know what as I was wrighting this I think I just figured it out tell me if I'm right or not. You need to connect the driver a from the ocilator to the drive a on th diver same with the drive b. Now the interupter cable has a output cable called enables connect that to enables on the driver. I forgott to check to check the links links so I'll post another comment to end your troubles. looks cool to so I'll have to build one too.
guyfrom7up
guyfrom7up
Answer 12 years ago
very subtle there :P yellow wire-goes to RF ground (say, a copper water pipe, don't use the 3rd prong in your house because it might damage all of the equipment in your house, but it might not matter since this is tiny) in the schematic simply connetc A to A and B to B, lol, not rocket science here. darn straight it goes from 12 volts to a higher voltage :P but unlike a conventional coil where there's high voltage in the primary (several kilovolts) it's all done at a lower voltage (say, 12 volts in this case) at higher current. More about the circuit: The 4 diodes are for preventing inductive kickback (ie large negative voltage) uhhh... I don't feel like looking up the chips now, but basically it self resonates (duh)
comodore
comodore
Answer 12 years ago
Could you please tell me are the components(HEF4049 ; IXDD414 ; UF5408) that I found on this site: http://export.farnell.com/ , the components that I need for this project?
Can't find it, do you know a store that sells these and ships them to Europe...
  • UF5408
Here there a re 2 group and one group has 1 product and the other 3, witch, precisely diode do I need???
http://export.farnell.com/jsp/search/browse.jsp;jsessionid=YDEIFA2WGNGCYCQLCIRZKBQ?N=0&Ntk=gensearch_001&Ntt=UF5408&Ntx=&suggestions=false&_requestid=527443
Thanks!
Grateful comodore!
guyfrom7up
guyfrom7up
Answer 12 years ago
HEF4049 is a chip containing multiples inverters (high in=low out, low in = high out, high=12 volts, low = gnd/0 volts) that have high current capabilities.
IXDD414 is a highspeed mosfet/igbt driver
UF5408 are very fast diodes
your links all lead to a country page, probably cause I'm in the US
comodore
comodore
Answer 12 years ago
-Yea, that you chose your country and you enter the site...
Please enter the site and do a search for :
  • HEF4049 (only 1 product and yes, it's a chip)
  • IXDD414 ( 0 products, where can I find that diode, do you sell them???) :D
  • UF5408 ( 4 products in total separated in 2 groups)
Please, look at the products and tell me if they are the right ones???
Thank you!
comodore
comodore
Answer 12 years ago
Thanks guyfrom7up! I knew where to connect A and B but what about the Interrupter, where does the enable wire go??? Also, Vcc, whats that? Thanks !
guyfrom7up
guyfrom7up
Answer 12 years ago
Vcc in this case is probably +12 volts In most schematics, though, like with microcontrollers and such, Vcc is 5 volts. Most common values for Vcc: 3.3, 5, 12 In this case 12
comodore
comodore
Answer 12 years ago
Thanks!
comodore
comodore
Answer 12 years ago
The small Tesla coil with the spark gap that you are making, what did you make the top out of...aluminium foil??? Thanks!
guyfrom7up
guyfrom7up
Answer 12 years ago
I carved a toroid out of styrofoam, dunked it in polyurethane, and then coated it with aluminum foil. I think I'm going to make a new one, this one had too many bumps.
comodore
comodore
Answer 12 years ago
Cool, a real proses.... You are really into this stuff! :D
miiwii3
miiwii3
Answer 12 years ago
https://www.instructables.com/id/Step_By_Step_Plans_to_Building_a_250000_Volt_Tesl/connect the enables in the interuppter to the 2 enables in the driver circut. the 2 antennaes must go to the coils a.k.a. the white wires in the second pic the yellow wire must be ground. I don't know 4 sure if i am right so build the circut how i told you and build a tesla coil how this guy did. The way I see it is your are boosting the power off a 12-18 vlt battery to a highr voltage a.k.a. the driver circut and connect the out put to the tesla coil. I only did this for the small one with a door nob for a ball so i don't know if this will work fo the the second mini tesla coil. I hope this helped you If it didn't go to my account and post your Question there.
miiwii3
miiwii3
Answer 12 years ago
that is the link at the top to how to build tthe coil sorry I don't have the schematic program on ths computer.
comodore
comodore
Answer 12 years ago
OK, the pictures re to blurry but I think I can make out everything.... Thanks!
comodore
comodore
Answer 12 years ago
Thanks miiwii3...you did help a lot...now its time to gather materials and get this project started... :D
The_Vinninator
The_Vinninator
12 years ago
so do you want the schematic explained? or do you want a drawing? or a picture? or what exactly? can you be slightly more specific? also, does this have anything to do with the electromagnet you were making?
comodore
comodore
Answer 12 years ago
  • Yes, that would be very very very helpful....Thanks
or a picture?
  • Shore, why not... :D
  • If I get the drawing or a picture, I think that will not be needed...
  • Yes, look up... :-D
  • No...I am just working on multiple projects at the time...first I want to do the Tesla coil and than....
Thanks!
The_Vinninator
The_Vinninator
Answer 12 years ago
sorry, this might take a while you're not it a rush, are you?
comodore
comodore
Answer 12 years ago
huh..Thanks! :D I think I can make out everything.... :P Do you think you could use Photo Shop or some other program and cut each segment and attach it, maybe... i am very grateful for this drawing but when working with High Voltage I want to be 100% I am connecting everything as it should be! Thanks!
The_Vinninator
The_Vinninator
Answer 12 years ago
you mean zoom in on each part? sure, I can do that
comodore
comodore
Answer 12 years ago
  • UF5408
Thanks!
Grateful comodore!
The_Vinninator
The_Vinninator
Answer 12 years ago
diodes are very forgiving if you use the wrong one by accident, it shouldn't change the process much at all I'd tell you, but the site is down right now, sorry pal I'm working on the image this is taking really long
comodore
comodore
Answer 12 years ago
I'm working on the image -Yay! Thanks a lot! Take your time, I am not in a hurry! :D
The_Vinninator
The_Vinninator
Answer 12 years ago
sorry, I just checked the schematic anything with that serial number will work so ya, you've got what you want
