1005Views6Replies
Author Options:
Build a small fan for a toyota forklift Answered
Need help building a small fan for a toyota propane powered forklift. Gets really hot in the warehouse and cant find a commercially available fan. the plug is really weird and isn't a 12 volt Any ideas
lemonie
lemonie
10 years ago
I's got a battery for the electric-start? Open it up and tell us what you have. You could "crodge" wires between the battery terminals and the connectors I think.
L
EmmettO
EmmettO
10 years ago
I'd get a meter and see how much voltage it is putting out. Then try and match a motor to that voltage. It's not as hard as it sounds, some motors like the ones in power tools and vacuum cleaners can run off AC or DC. If it's running at 36V you might be able to run a fan off it. I'm trying to think of the easiest motor to harvest and try. It might be a vacuum motor but that would depend on what you have available.
Re-design
Re-design
10 years ago
Connect directly to the battery with clips and a switch.
frollard
frollard
Answer 10 years ago
Trouble is might be a 36, 48, or some other ridiculous voltage coming out of the forklift - that said, the engine must have an electric starter, probably 12 or 24 volt...so ensure the fan is the right voltage.
caarntedd
caarntedd
Answer 10 years ago
And an inline fuse.
Re-design
Re-design
Answer 10 years ago
Yeah. I should'a said a fuse also.
