2235Views4Replies
Building a 3 x 3 x3 LED Cube controlled by an Arduino?
I built a 3x3x3 LED cube and tested it. Since I'm new to electronics and micro programmable processors I'm having a difficult time connecting the cube to the Arduino and haven't had much luck getting information fundamental enough for me to grasp. I've tried a few ways and as you would expect, trashed a few LEDs to say the least. Since the digital pins output 5 volts I can't figure out how to connect the 9 anodes and the common cathode per level. Can anyone help?
Thanks,
11 years ago
I'm having troube forming the 3x3x3 Cube. If anybody knows of any good pictures/tutorials on it, a link would be appriciated.
https://www.instructables.com/id/The_Arduino_LED_Cube/ did NOT help with forming the cube one bit.
Answer 9 years ago
I had the same problem as you.... I was confused on how to connect each layer together. I fixed this by soldering a 1 inch piece of copper wire to the anodes (the longer one)that runs up beside the led. That way I could connect the layer ontop of that to the wire and not have to run down past the led. Does this make sense?
10 years ago
This one is very good. https://www.instructables.com/id/LED-Cube-and-Arduino-Lib/
11 years ago
Try looking at this instructable.
https://www.instructables.com/id/3x3x3-LED-Cube/
