371Views20Replies
Author Options:
Building a flasher circuit with a single led to flash Once, then Twice, then Three times, and then loop it? Answered
I've built some simple flasher circuits in high school, but what I need now requires a bit more than a simple flasher. I want to avoid using a micro controller or arduino. I hope there is a simple way to just loop a simple flasher circuit through multiple stages of capacitors or something, but that's why I've come here. :) This is what I need:
A flasher circuit with a single LED, flashing in 3 sets before looping.
It will flash ONCE (Beep). And then TWICE in quick succession (BeepBeep). And then THREE times in quick succession (BeepBeepBeep).
There needs to be a delay between each set of flashes. After the 3 sets of flashes, it will loop and do it again and again.
I would love lots of help on this! Thanks so much.
rickharris
rickharris
Best Answer 4 years ago
Sorry I missed the bit where you want them to work in opposition
I will leave the other prog up as well though
Start:
High c.2
for b1=1 to 3
sound c.1, (126,50)
next b1
low c.2
wait 2
for b1=1 to 2
High c.2
sound c.1, (126,50)
pause 25
low c.2
next b1
wait 2
for b1=1 to 3
High c.2
pause 25
low c.2
next b1
sound c.1, (126,50)
wait 2
goto start
AdysonW
AdysonW
Answer 4 years ago
Am I on the right track with this? :P
rickharris
rickharris
Answer 4 years ago
More or less the interface manual I linked to has drawings of how to connect various things.
To program the device your going to need a programming cable, you can make one if you have a serial port on your PC.
Your going to need to build or buy the programming circuit, this is a couple of resistors. See the manual or my Instructable.
Your speaker doesn't need to go through the resistor.
The manuals contain all you need to know.
rickharris
rickharris
Answer 4 years ago
I should have added the images come from the Picaxe manuals, thanks Picaxe,
No connection to c.3. required
You can download the programming editor for free, it contains a simulator that allows you to run your program without having the processor.
The prog is text so you can cut and paste my work into the editor.
AdysonW
AdysonW
Answer 4 years ago
I'm reading through the manuals, thanks so much. You've all been a lot of help.
AdysonW
AdysonW
Answer 4 years ago
And I just noticed this update to your last answer, thank you so much! :D
iceng
iceng
Answer 4 years ago
A little chip is the way to go, welcome to the soft-ware group.
A bit of advice everyone can do C programming, so if you have a natural gift of uP ability, do take the time to learn machine code to make you way more employable...
Machine code can do those things that a compiled language like C is too slow to do a desired function like radar or satellite packet re-assembly...
AdysonW
AdysonW
4 years ago
Wow, such fast replies! That's wonderful, thank you for the explanations, and the links. That's perfect.
Since we're using a microprocessor, if I wanted to include a second, identical circuit where instead of a flasher, it had a beeper, could I use the same microprocessor?
To clarify: I want to expand this project to include a beeper with the flasher, in the same 1 2 3 pattern, but opposite in rhythm.
Flasher Rhythm: 1 2 3
Beeper Rhythm: 3 2 1
What would that look like and can I use the same microprocessor, or is it just easier to have two duplicate, separate circuits?
rickharris
rickharris
Answer 4 years ago
No it will all fit in the one micro. Slightly more sophisticated but understandable I think.
Start:
High c.2
wait 1
low c.2
sound c.1, (126,50)
wait 2
for b1=1 to 2
High c.2
sound c.1, (126,50)
pause 25
low c.2
next b1
wait 2
for b1=1 to 3
High c.2
sound c.1, (126,50)
pause 25
low c.2
next b1
wait 2
goto start
rickharris
rickharris
Answer 4 years ago
this has been simulated and works fine. No idea on the timings you want/need but they are easily altered. Wait = seconds pause = milli seconds (ie 1/1000 of a second)
AdysonW
AdysonW
Answer 4 years ago
Aha, that's perfect! Thank you so much for all of your help, I learned something! :)
iceng
iceng
4 years ago
Here is that circuit with quick LED flash blips followed by longer pauses endlessly repeating on a 12V power supply.all the timing is easily controlled by R1,R2,R3 and a 1uF 25v capacitor
Be sure to click on the pic to see the entire image !
I designed this circuit just for your application. Any opto-isolator should work by bypassing a resistor to accelerate the 555 timer.
If this is the best answer then click that button for me please
steveastrouk
steveastrouk
Answer 4 years ago
Very clever. Just shows you don't HAVE to use a micro, but you have to admit, with something like a Tiny or an 8 pin PIC, its easier.
iceng
iceng
Answer 4 years ago
Yes, a micro would be my first choice like every one here...
It's sooo much easier but what is life if you don't try to do a convolution now and then :-)
steveastrouk
steveastrouk
Answer 4 years ago
I passed your solution round to my junior colleagues to show them how it should be done, old school. Its an important lesson
steveastrouk
steveastrouk
4 years ago
It can be done with discrete logic - lots of discrete logic - but really, it would be vastly simpler to use a single chip like an ATtiny.
rickharris
rickharris
Answer 4 years ago
Taylor made for a microprocessor! (sorry for the pun)
picaxe 08M
Code:
start:
sound c2,(126,50)
wait 10
sound c2,(126,50)
wait 1
sound c2,(126,50)
wait 10
sound c2,(126,50)
wait 1
sound c2,(126,50)
wait 1
sound c2,(126,50)
wait 5
goto start
This makes a sharp beep for 1/2 a second, waits 10 seconds makes 2 beeps 1 second apart waits 10 seconds makes 3 beeps 1 second apart. waits 5 seconds and does it all again.
You can make this more complicated, change the time intervals and even make it play a tune rather than a beep if you like.
Needs a piezo sounder attached to the output c.2 it is pretty loud I have something similar for a door bell.
https://www.instructables.com/id/Lets-Program-a-PIC...
rickharris
rickharris
Answer 4 years ago
Sorry just reread the question and I see you want to flash an LED.
Easier.
Start:
High c.2
wait 1
low c.2
wait 10
high c.2
wait 1
low c.2
wait 1
high c.2
wait 1
low c,2
wait 10
high c.2
wait 1
low c.2
wait 1
high c.2
wait 1
low c,2
wait 1
high c.2
wait 1
low c,2
wait 10
goto start
As before the LED is connected between output c.2 and ground with a 330 r resistor in series.
