Alright, If you want a powerful ram-rod gun, I would suggest a simple trigger like the one on my dragunov, or a block trigger attached to a real trigger. For a slingshot, use a ratchet, they are easy to start with.
Yes, i do believe seeing yours before, I was going to use that type of true trigger but I was working with a experemental ram, and it just wasn't going to work. I went with a pull pin for an experementat test phase, in which i discoved my entire back half was not near strong enough, and my ram to be a fail. I going to make a different gun from the ruins. Im not just starting either. Slingshots arnt great. I like guided ram rod systems where power can be maximized without rod breakage I could use a block trigger, but i find them crude and in effective. Also, on your gun, I would suggest making a ram guide, preventing bending/breaking of your rod with too much power. Thanks for your response.
On a side note, you said you achieved 65 ft with your gun. I'm curious as to how, because I can shoot through 2 layers of cardboard or pop cans, but after 30 ft or so, my ammo, ive tried everything but greens, will begin an series of twirling flips which stop it within 5 ft of the first flips. I have tried finnammo to. I found it hard to make, load and found it ineffective. more or less bands had no effect, but less slightly reduced distance is all. Also, how many bands you use?
Best Answer 10 years ago
You should try the TR-18 or the NAR trigger they have never failed on me, and they are very easy to pull back.
Answer 10 years ago
Yea, its what i usually use, somthing like that, just I have found them to fail at high forces.
10 years ago
Try making a working barret 50 cal i made one and it shoots 80ft
10 years ago
Answer 10 years ago
Answer 10 years ago
