80Views3Replies
Author Options:
Building a taller lift for my chair Answered
So, I own an  adjustable bar-height stool with min-height of 24" and max-height of 33" and I wonder if it is possible to either
1) retrofit the existing hydraulic lift so I can get 10" more in height
2) Or completely build from scratch a similar hydraulic lift as the one I currently have installed except the new one would provide a max height of about 45"
I would appreciate any tips in accomplishing either of the above listed options please.
rumpells
rumpells
4 years ago
I think if the minimum goes up about 5", I would not mind. And I do anticipate changing heights often as I will need to move from desk to workable throughout the day.
I do have two hydraulic chair lifts I would have loved to use in building the new taller one. My original idea was to find a way to stack the hydraulic lifts one on top of the other, so I end up with a chair with two points of adjustment, but I still have yet to find any information on how to go about doing and testing t.
Toga_Dan
Toga_Dan
4 years ago
most hydralic rams lift a lot more than the few hundred pounds a chair holds. They will also lift a lot slower. Just thinkin out loud.
Do u still want the 24 in min? And do u anticipate changing height often?
crapflinger
crapflinger
4 years ago
if you don't care that the minimum height would change, you could just add some blocks between the current lift and the seat to increase the max height.
