282Views6Replies
Building blocks associated with Arduino 433 Mhz transmitter & receiver
Newbie here. I want to make a temperature monitor that will transmit an alert signal to a receiver. If I use the little 433Mhz Arduino RF transmitter / receiver modules, what would I need with them? I know these can be attached to the Arduino programing boards and are made functional by a computer program, but I don’t want to stick the Arduino program board & computer under the house where I want to measure the temperature. I’m confused by this. I understand these little units are used in remote control cars & planes, but what do they get connected to?
6 years ago
The simple 433 TX and RX transmit serial data. So they are fed from a single pin on the micro controller. At the RX end if you need to assemble the data into a string again you will also need a microprocessor.
I would expect there are numerous sketches to do this for the Arduino.
the data sheet fr the relevant TX RX set up should show you how.
Answer 6 years ago
Thank you for responding. The rec & xmiters had no data sheets. Would attaching a (embedding) programmed, "Pro Mini atmega328" to the transmitter & receiver, along with the peripheral parts (battery, sensor, relay etc) do the trick?
Answer 6 years ago
http://www.picaxestore.com/index.php/en_gb/picaxe/...
link to a data sheet for 433 Tx and RX
Answer 6 years ago
These are not the same modules I have. Mine are the ones in the attached pic.
Answer 6 years ago
It might have helped if you gave some kind of identification - Numbers or names.
The point I was making is that the principles of operation are the same as the data sheet i directed you to.
6 years ago
You can roll your own "arduino" clone from a few cheap bits which will do just what you want.
Answer 6 years ago
Depending on my location I would use the Picaxe - They arrange for attaching radio and make life easy.
