148Views3Replies
Author Options:
Built self-watering plant project (by randofo). Can I get help troubleshooting? Answered
Arduino fires up okay, but I can't get the relay to energize, so the pump does nothing, of course.
Great project, but some of the steps aren't clear enough for this retiree. For instance, in Step 23, "Plug the black wire from the circuit board to the ground socket on the Arduino." Which "black wire?"  There is no complete schematic, so I'm guessing at what I'm trying to find.
Also, the Arduino sketch in Step 19 (Randy Sarafan) didn't compile or load into the Arduino until I inserted the missing semicolon after the line
"int dryValue = 700"
Could sure use some help, as Mama is looking forward to having her vegetable plants watered when we're not home!
Thanks in advance!
--Fred Lochner, Boulder, CO
Kiteman
Kiteman
Best Answer 7 years ago
If you post this question in the comments of the project, or PM Randofo directly, you'll get the answer you need from the author.
astroboy907
astroboy907
Answer 7 years ago
+1 Randofo is usually really quick with help
fredlochner
fredlochner
7 years ago
Arduino fires up okay, but I can't get the relay to energize, so the pump does nothing, of course. Great project, but some of the steps aren't clear enough for this retiree. For instance, in Step 23, "Plug the black wire from the circuit board to the ground socket on the Arduino." Which "black wire?" There is no complete schematic, so I'm guessing at what I'm trying to find. Also, the Arduino sketch in Step 19 (Randy Sarafan) didn't compile or load into the Arduino until I inserted the missing semicolon after the line "int dryValue = 700" Could sure use some help, as Mama is looking forward to having her vegetable plants watered when we're not home! Thanks in advance! --Fred Lochner, Boulder, CO Follow Question 172 Kiteman says: Jul 9, 2013. 5:19 PMReply If you post this question in the comments of the project, or PM Randofo directly, you'll get the answer you need from the author. 9 astroboy907 in reply to KitemanJul 9, 2013. 8:17 PMReply +1 Randofo is usually really quick with help Related Self-Watering PlantSelf-Watering Plant by randofo Create the Arduino driven LED growboxCreate the Arduino driven LED growbox by cpo Singing plant. Make your plant sing with Arduino, touche and a gameduinoSinging plant. Make your plant sing with Arduino, touche and a gameduino by madshobye Self Sufficient Arduino BoardSelf Sufficient Arduino Board by p2man Arduino Microcontroller ProjectsArduino Microcontroller Projects by janisalnis Hear your plants play music! (WIFI version)Hear your plants play music! (WIFI version) by mattomatto make a self-watering planter using recycled materials on the cheapmake a self-watering planter using recycled materials on the cheap by calskin Hear your plant make music! - Ethernet versionHear your plant make music! - Ethernet version by mattomatto self watering trayself watering tray by gauravclb96 Autonomous Greenhouse FactoryAutonomous Greenhouse Factory by pablopeillard More Related About This Topic 17 views Posted: Jul 9, 2013 fredlochner Follow0 Tags:selfwatering plant project
