208Views2Replies
Author Options:
CFL AND DIRECT BOX QUESTION(s)? Answered
This is a multi part question.
1. What normally fails on a CFL bulb?
2. If I scrap a good used transformer from a CFL will it work to build a direct box?
I know it is pretty easy to buy a Jensen Trans or other brand new trans for a DI box but how many dead CFL bulbs do you see waiting to be reused or recycled? I would really like to reuse the tranny if possible.
My understanding is that heat is causing a great number of the premature deaths in CFL bulbs.
see images.
Thanks
AFF
orksecurity
orksecurity
9 years ago
Personally, I haven't yet seen a CFL bulb _fail_. I've seen phosphors wear out to the point where it wasn't as bright as it should be.
As far as the transformer goes: TRANSFORMERS ARE NOT ALL INTERCHANGABLE. The number of turns on the two coils affect how current and voltage are traded off. Efficiency varies. Since inductors are a nonlinear component, how well they pass which frequencies through varies.
I *think* a DI box uses a 1:1 transformer, which these definitely will not be.
frollard
frollard
Answer 9 years ago
Generally in a cfl the electronics die years before the phosphor wears out. What exact part I can't say, but probably some diode, transistor, or cap that wasn't rated for the eventual needs of the bulb...
Good info!
