82Views3Replies
Author Options:
CG and CP? Answered
You state that CG should be above CP, but this terminology is slightly ambiguous. Usually people say that the CG should be forward of the CP or the CP should be aft of the CG. I realize these are not terms everyone knows, but once you understand them it makes things more clear.
mikeasaurus
Best Answer 2 years ago
True, but I am keeping this class very simple in concept and vocabulary. Rocketry is such a deep field with so many more forms than what I show here.
NikhilK123
2 years ago
CG:Center of Gravity
CP:Center of pressure
The reason he uses the term 'above' is because the rocket is moving vertically up.If the CG is above the CP,the rocket can maintain a state called 'stable equilibrium',such that if it tilts, it turns back to its vertical up state.This is similar to case when the north pole of a magnet pointing north is given a slight push(it turns back to north). If CG were below CP,we would have 'unstable equilibrium'. This is dangerous for a rocket!In this case any small disturbance(tilt) can flip the rocket from up to down just like a magnet flips orientation when you make the north pole point south.
nexgencodecampNikhilK123
Answer 1 year ago
Thanks for this. I'm having difficulty understanding CP but this explanation puts another piece of the puzzle together.
