14541Views5Replies
Can I build a Tesla Coil using a flyback transformer instead of a neon sign transformer?
If yes, what changes would there be in its design from one that does use a neon sign transformer? If not, what can I do with my surplus of flyback transformers?
Best Answer 12 years ago
Yes, it is possible. Most people call flyback drivers "SSTCs", when they really aren't. Use the schematics here: http://tacashi.tripod.com/elctrncs/555sstc/555sstc.htm to build the driver, and then hook the output up to a standard LC circuit with a spark gap. It will not be as powerful as a NST powered coil, but if you tune it right, here is an example of what you will get. Note that you should use a modern flyback transformer with a built in diode because you cannot charge capacitors with high frequency AC. The advantage to a DC type coil is that you do not need to match the capacitor to the transformer, you can use a capacitor as large as you want.
Answer 12 years ago
Oops, here's the link to the video:
http://video.asterpix.com/v/247740311/my-mini-sgtc-tesla-coil/
11 years ago
yes. but the resistors will heat up fast for many things that you use. i used neon transformars. which still i burned something in it
12 years ago
In my slideshow, I used a flyback transformer.
https://www.instructables.com/id/Tesla-Coils-for-Dummies/
12 years ago
http://www.aaroncake.net/CIRCUITS/hvgen.asp
You should give this a once over. I can not stress the importance of a good SOLID ground. DIRECTLY TO THE EARTH. when ever using High Voltage.
"I am sorry Dave, I can not do that."
