340Views3Replies
Can I connect the output of the recorder ( BNC ) for my wireless security cameras to an LCD flatscreen monitor ?
The flatscreen monitors I have seen have d-sub connectivity. My recorder has a bnc output ( analog?) connection. Manufacturer says the output can be sent to a tv set so I assume it is an analog signal. I want a nice size screen but small unit than a tv set for desktop. Can this be done?
10 years ago
yes... you will need a number of components, but it is doable.
you will need a:
http://www.amazon.com/GRANDTEC-GVC-1000-Console-Converter-Svideo/dp/B0007L81YE/ref=sr_1_11?ie=UTF8&s=miscellaneous&qid=1252546646&sr=8-11
and the approprate bnc to rca adapter. you hook the bnc camera to the rca adapter ($5 bucks at radioshack) and then plu into this box. it will convert the signal so the monitor can use it.
if u hav more than 1 camera, you can buy video multiplexer boards that will combine 4 images into a grid
Answer 10 years ago
Thanks for the answer! I went to your link and bought the box. It seems to be just what I need. Thanks again!!!
Answer 10 years ago
no problem. we use these converter boxes for underwater cameras on robots so that we can use some of the lcd monitors we have.
