4863Views5Replies
Author Options:
Can I convert mains fairy lights to battery powered lights? Answered
I want to make a fancy dress costume lit with some old mains fairy lights (that I have lots of) can I do this? Do I just cut off the plug and fix to a battery. Or will there be too many lights, too dim to see?
steveastrouk
steveastrouk
11 years ago
Its not so much the power, as the voltage - go for Lemonie's LED idea, safer and more practical.
Re-design
Re-design
Answer 11 years ago
I second that. No way would I make a costume and attach lights that were plugged into the main power. Even if you build safely how do you know that someone won't spill a drink on you in the wrong place. With it a part of your costume you couldn't get away from it. Better to use low volts and parallel leds.
seandogue
seandogue
Answer 11 years ago
Pippa is asking about hooking them to batteries, re-design, not connecting to an AC source. There is nothing unsafe about her idea. It's just energy inefficient.
"Do I just cut off the plug and fix to a battery. Or will there be too many lights, too dim to see?"
Re-design
Re-design
Answer 11 years ago
My mistake. I didn't read the question carefully enough. Yes a battery would be perfectly safe.
lemonie
lemonie
11 years ago
These take a fair bit of power, you'd have to rewire them and use a big battery. Starting again with LEDs might be better. L
