If the install will go far enough to be able to access the windows/system files, I'm fairly sure that there was a file from which the product key could be read, although that may only be possible once you have installed, so still requires a key. Worth looking up though, just in case it works.
If you really can't find the key, you could try looking for a crack (I'm assuming that this is a legit copy, although the legality of using a crack is still questionable).
Just borrow a XP home disk from someone and then use your key. If the key is valid it should work with most of the install disks. I have run into trouble with the various service packs though. Some of the older keys don't work with the newer service packs and some of the new keys don't work with the older discs. So try to get a SP2 disc since they seem to be more universal in terms of keys.
7 years ago
Kinda like a "hachintosh".
8 years ago
Completely no. Even the same kind of disk have the same key!
9 years ago
Sometimes if you call microsoft and ask the right way (like you lost the activation codes) they will help you get a new code for xp pro
9 years ago
9 years ago
9 years ago
No, but if it is anything like windows 7, you should be able to download the trial of xp home and activate it with your key.
9 years ago
You need a product key that matches the install disc, so "no, not just like that".
L
