122Views1Replies
Author Options:
Can I make a light organ with a graphic equalizer? Answered
I have a Fisher CA-39 amplifier with an integrated graphic equalizer. I want to make a light organ and instead of starting from scratch I thought maybe I could use this graphic equalizer I already have. I know that the equalizer splits the audio into 5 frequency ranges and then allows you to adjust each one individually, So I guess my question is can you hijack the broken up signal before it reconstitutes it into a single output and then put it to lights(ideally LEDs) instead of speakers?
frollard
frollard
8 years ago
If you look inside at the circuit there are probably very obvious circuits that split into the many channels, each running through a different set of chokes to give the frequency bands for each channel. Tapping in there should allow for a signal you could apply to a light-organ bar graph.
