86Views5Replies
Author Options:
Can I mix cement, aggregate, and water in place? Answered
I have a 250 sq. ft. area that has 2" of pea gravel on top of clay.  Can I mix cement into the gravel then water from the top to get a surface hard enough to put pavers or stones on?
Tags:cement
Vyger
Vyger
4 years ago
I would say no because you need to really mix the water and cement and I don't think you could get proper mixing if you just poured water on the cement on the ground. You could mix the cement in a container, like a wheelbarrow, pour it on the gravel and then mix it into the gravel, but the cement really needs to be mixed properly first.
Besides, a lot of your water would probably run off into the gravel before it mixed in if you just poured the water into the cement..
steveastrouk
steveastrouk
4 years ago
Is there a geotextile between the clay and the gravel ?
steveastrouk
steveastrouk
Answer 4 years ago
Just blind the surface with sand, and lay the pavers like Rick says then.
rickharris
rickharris
4 years ago
A lot depends. In principle I guess so.
However pavers are normally laid on a sand bed.
