1068Views4Replies
Author Options:
Can I place two speakers back to back in a box, any issues being too close or touching? Answered
2.5w 8ohm 3" speaker in a plastic box 1cm apart, possible to operate?
Kryptonite
Kryptonite
Best Answer 11 years ago
Yeah that'd be fine, the magnetic force doesn't effect the internal moving piece that's attached to the diaphragm on the other one, well it might but not significantly enough to make the sound different.
I tried because I wanted a set of speakers for my computer, I used 2.5" speakers, 2.5w 8ohm if that helps.
samuelayomide13
samuelayomide13
1 year ago
Can I put the speakers back to back touching each other
celalboz
celalboz
11 years ago
Thanks a lot all of you, box is 3"x6"x7" and speakers (2.5" 8 ohm) are not touching, 2 cm apart back to back.
thanks again..
jeff-o
jeff-o
11 years ago
Should be fine, as long as there isn't a direct short.
orksecurity
orksecurity
11 years ago
Not sure whether you'd be risking phase effects. Depends on the size of the box...
