6323Views4Replies
Author Options:
Can I repair a flex ribbon cable? Answered
Is there a way to basically bond or splice two ribbon cables together? I have an expensive mouse and it was dropped. The cable was severed, and I want to know if I can repair it, because it's sort of oddly shaped and isn't just a straight cable like the kind I could buy from Digi-Key or something?
It is attached to the ball control circuit thing of an iMac mouse. It can't just be replaced because it's built into a tiny flexible circuit. It is the kapton type.
kelseymh
kelseymh
Best Answer 10 years ago
Pictures?  Is it regular ribbon cable -- multiconductor, light blue?  Or is it a kapton/trace hybrid?  With the former you could use a cable header and just crimp two cut ends together.  Hybrids are really tricky to "repair" -- it's more reliable to replace it.
MdP1632
MdP1632
Answer 10 years ago
It is a kapton cable.
kelseymh
kelseymh
Answer 10 years ago
Oh.  Sorry to hear that.  The few times we had bad hybrids on the BaBar silicon vertex tracker, they just removed and replaced them.  It sounds like you aren't in position to have a bunch of spares around.
We do have some serious hardware gurus on site.  Hopefully one of them will have experience with these sorts of repairs.
frollard
frollard
Answer 10 years ago
Seconded.  Worst case scenario you could reverse engineer the connections and jumper (solder) fine wire between the connected elements - not ideal I know.
