Yes I need to reuse it, its only a few months old, my wheel studs are bent on all four wheels, I was going to take the assembly off to knock the studs out, I figured it would be easier
I was told by a mechanic if I was to remove the hub assembly and remount it, the bearing would spin and I'd probably lose a wheel going down the road. Would this happen?
Ok the bearing and hub are one piece, its got the studs on it, the bearing and hub ( one piece. ) bolt to the spindle with 3 bolts. I just want to know if I remove this hub assembly can I put it back on without spinning the bearing
9 years ago
What for ?
Answer 9 years ago
What do you mean?
Answer 9 years ago
He means, do you want to put it back on the car or are you trying to re-purpose it for some other use.
Answer 9 years ago
Answer 9 years ago
As long as it's not damaged ofcourse you can still use it.
Answer 9 years ago
If its good, and its off the vehicle you want to use it on, what's the problem ?
9 years ago
Answer 9 years ago
Nah, get a bearing locking adhesive (Loctite) from a bearing store.
Take care knocking the bearing out nicely parallel and you should be OK.
There is usually a secondary method to stop the wheel coming off anyway.
Steve
Answer 9 years ago
Answer 9 years ago
I can't comment further, because of the safety implications, and the fact I can't see the bits ;-)
Steve
