1256Views1Replies
Author Options:
Can I solder a wifi antenna to these points on my receiver? Answered
Hi,
I have an antenna (see picture 1). Is this antenna appropriate for using as a WiFi extender?
And how should I solder the wires from the antenna's to the print board? (picture 0)
DustySeven7
Best Answer 8 years ago
Yes that is a wifi antenna. You do not actually need to solder at all. The antenna you have is connected to a coaxial cable by a sma connector. The little brass squares with a circle is u.fl connector. This is used mainly for laptop internal cards. You just need a pigtail from u.fl to sma. Since there are two that means the device has a main and a secondary. The connector and surface antenna next the 1 on the top right is your primary. You get away with just a antenna on the primary but you will better results with antennas on both.
Hope this helps You.
