2117Views7Replies
Author Options:
Can I turn a laserbeam in a Bigger and wider beam?? Answered
Hi, I'm working on a new project and it involves a detection using a Laser... Because the beam is to thin to detect an object i need to increase the thickness of the beam... Is this possible using some sort of lenses? or is there an other way of doing this? Thanks for helping! Greetz Kenny
lemonie
lemonie
11 years ago
Bounce it off mirrors like you see in films? L
zupperzipper
zupperzipper
Answer 11 years ago
No it's just needs to dedect a small magnet passing the laser
lemonie
lemonie
Answer 11 years ago
Magnet? Is there a magnetic aspect to the mechanism? L
zupperzipper
zupperzipper
Answer 11 years ago
I'll post the project as soon as it's working :)
frollard
frollard
Answer 11 years ago
ooh ooh...tight diffraction grating to make a series of dots, each with its own sensor...
lemonie
lemonie
Answer 11 years ago
It's Sunday evening, and you're giving me something to think about... yea, I like the idea. L
frollard
frollard
Answer 11 years ago
I second this one...depending on the size of area needing coverage, you might need a very precise mirror - tinned glass mirrors tend to split the beam with the refraction and internal reflection of the beam going different ways.
lemonie
lemonie
Answer 11 years ago
I think it's area-coverage or something-like that's needed, aligning them would take a bit of work but I don't see it as being much harder than the idea pictured above ? L
orksecurity
orksecurity
11 years ago
The other solution to just use mirrors to bounce the beam back and forth a few times before it hits the detector, creating a grid wide enough to detect the object. If that works for you, it should be easier to work with than widening and then narrowing the beam -- the wider beam will become dimmer if something passes through part of it, the bounced beam will go out completely if something passes through any part of it.
jtobako
jtobako
11 years ago
If the initial beam won't get detected, the wider one won't either. You detect the power level of the beam, so just widening the beam won't help, you need a stronger laser source.
steveastrouk
steveastrouk
11 years ago
Well you COULD use a graded index lens (GRIN) lens, but, a beam expander made from a pair of lenses is easiest. Look for "beam expander" on Google.
