53Views3Replies
Author Options:
Can I use 60ppi polyurethane to filter solder smoke? Answered
I am going to make myself a little rig. Two fans with some kind of filter sandwiched in between. I was wondering if polyurethane filter would work because I saw it and it was extremely cheap. 60 ppi seems like the best filter quality I can find. Then again I don't really know what I'm talking about. If someone could explain to me why this is a bad or even a good idea that would be appreciated. Also any recommendations on anything else I should use instead. :)
Downunder35m
Downunder35m
1 year ago
I do quite a bit of soldering and if there is one thing I learned then: Location and air volume transfered matters.
Years ago I bought a filter fan.
Was used for a day until I started trying to fix it.
Then I had small but quite and powerful fan from an old breathing machine.
Placed in a box with just a layer of these wonder soaker cloth in front.
(I use the same to clean the tip).
Before I use I sprayed a bit water onto the cloth and all was fine fore a few hours.
In all cases though this was of little help to deal with the smoke that escaped while actually soldering.
Ended with sort of a soldering box, like trying to solder in some wind tunnel LOL
I fixed this for good by simple removing the filter stuff and adding some flexible airvent hose.
One end points to where I need it, the other just goes out of the window...
Inblackandwhite
Inblackandwhite
Reply 1 year ago
It sounds like a nice fix. Just pumping all the nasty stuff outside. I want to build something for my bedroom though where my desk is. It's on the complete opposite from the window so I would need to get something quite large to get it all the way over there. Also I have the AC running because it's hot here and it would be best if I didn't have to crack the windows. There has to be some kind of filter that if layered enough absorbs solder smoke, right? It would really great if there was.
Downunder35m
Downunder35m
Reply 1 year ago
As said, these wonder soakers, if a bit wet filter almost everything out.
But you might need a more powerful fan than what you get from an old PC power supply.
You can also check online for cigarette smoke filter or room air cleaners.
They usually come with a strong fan and a carbon filter pad.
Should work good enough but you might have to replace the pad every few months if serious about the soldering.
