984Views3Replies
Author Options:
Can I use a 3.5" hardrive enclosure for 2.5" harddisks (SATA)? Answered
Will it damage my harddrive if I use a 3.5" hardrive enclosure for 2.5" harddisks (SATA)? The connectors are the same...
NachoMahma
NachoMahma
11 years ago
. If the enclosure is designed for SATA drives, your only problem is physically mounting the drive. You should be able to easily buy/build mounting adapters.
Fypsigon
Fypsigon
Answer 11 years ago
When I said "the connectors are the same" I meant that physically mounting the drive is possible.... But...with the older IDE 2.5" harddrives I never had to connect any power supply....if I connect both SATA connectors will it get "to much power" and will kinda burn up? The enclosure is meant for 3.5" harddisks that need more power...
NachoMahma
NachoMahma
Answer 11 years ago
. As long as the voltage is correct, the drive will only pull as much power as it needs. If you connect a 5 W load to a 50 W PS, the PS will only put out 5 W. . But I'm not real sure what you mean by "if I connect both SATA connectors." . It might help to have more info on the enclosure and drive. Links?
