2605Views11Replies
Author Options:
Can I use a 50w 12v halogen bulb instead of LEDS on this cirucit? Answered
I have Made this circuit (in the link  and pic) with one LED, It works great and its one of the best instructables I seenand built, mainly because its easy, simple and has a nice outcome. (the pic is not mine, its motadacruz's)
I would like to know if I could use this with a 50w halogen bulb?, providing I supply another wattage and voltage.
https://www.instructables.com/id/Music-LED-Light-Box/step6/Building-the-circuit/
Thanks
Oscar
steveastrouk
steveastrouk
Best Answer 10 years ago
Not without some serious heatsinking of the transistor, and possibly uprating the transistor used.  Halogen lamps do not like being modulated like this
oscarthompson
oscarthompson
Answer 10 years ago
Thanks for you comment, do you think it could handle 1-3w ?
steveastrouk
steveastrouk
Answer 10 years ago
Yes, that's fine.
oscarthompson
oscarthompson
Answer 10 years ago
Ive been reading the data sheets it says The TIP 31C can handle 40w? and just to double check this is a product i am describing.
steveastrouk
steveastrouk
Answer 10 years ago
There's no problem driving that, you SAID you wanted to drive a 50W halogen lamp originally.
oscarthompson
oscarthompson
Answer 10 years ago
Its the closest I could find to a 50w halogen bulb!, i just wonder if it is bright enough?  I was thinking if I could split the load beetween some TIP 31C's? as I have already ordered the lighting transformer....before I published this. oops!
steveastrouk
steveastrouk
Answer 10 years ago
Try the LED lamp. It will be more responsive to sound than the halogen lamp, and you can put 10 of 'em in the same circuit.
A halogen lamp needs a different transistor, or a different circuit to drive it. You could look at a 2N3055 instead, but it MUST be on a substantial heatsink.
Steve
NachoMahma
NachoMahma
Answer 10 years ago
.  FWIW, the TIP31x is rated for 40W.
steveastrouk
steveastrouk
Answer 10 years ago
...not enough, and Ic max = 3A, this thing'll pull 4+
Its going ti struggle !
lemonie
lemonie
10 years ago
You're not going to get the same response from a halogen bulb. The heat-up/cool down time is significant, so you'd want fairly low-frequency on/off switching.
And for on/off switching you might think about a relay between the 12V and the transistor.
L
oscarthompson
oscarthompson
Answer 10 years ago
Thanks for your comment, I thought that after I wrote that....I have some lighting cans which use them and they do not have very good response unless warmed up.
Thanks
