6612Views7Replies
Author Options:
Can I use a 7mm socket instead of a 1/4 inch socket? Answered
Is 7mm close enough to 1/4 to work correctly?
lemonie
Best Answer 10 years ago
You can use oversize sockets with an insert, that is cut a strip of steel from a can & fold it to the 1/4" size, insert into socket. If you've got a lot of torque to pull on it I wouldn't advise it, light loading is fine. L
imrealldum
10 years ago
Thanks everyone!
Re-design
10 years ago
In an emergency I've used a file to reduce the nut to 6mm or whatever socket I had.
Kryptonite
10 years ago
The other comments cover it really, but I guess if you just asked around at different stores they might sell in inches.
kelseymh
10 years ago
To really do that, you'd need a 6.35 mm socket. So, if your nut is already worn down, a 6mm would work. With a 7mm, you're likely to chip or wear down the corners of the nut, because it will be too loose a fit.
orksecurity
10 years ago
Try it. If it fits, and fits tightly enough, it will work. If it's too loose, you risk rounding off the corners of the nut or bolt-head or whatever.
seandogue
10 years ago
All depends on the nut. sometimes they're worn enough, sometimes they're not.
