371Views3Replies
Author Options:
Can I use a nightlight's light sensor for a bigger project? Answered
I'd like to build a simple (if that's possible) light in my front hall that will turn ON when I open my front door, and stay on for 15 seconds (I want it to turn off by itself so I don't have to walk back through my apartment to turn it off manually). I thought about using the light sensor from a nightlight because every time I open my front door light pours in from the main hallway; I thought it would be cheaper than a motion detector. Can anyone help with the sensor ,or with the timing
seandogue
10 years ago
you can use the sensor, but remember that the switching circuitry is only meant for a very low wattage bulb, so it would have to be modified fro the desired load.
seandoguekelseymh
Answer 10 years ago
yeah, that's what I meant, although modding the entire plugin to directly power an (~mA in...50 @ 6W bulb) AC input relay from the terminals that feed the bulb socket isn't a bad idea at all...much simpler than what I had in mind. Crydom amongst others mkaes some nice AC input SSRs that will run from low current 120 VAC (and likely 240 as well)
