63574Views10Replies
Author Options:
Can I weld aluminum with a mig welder if I have flux core wire? Answered
My parents got me and my younger brother a mig welder for Christmas they also got flux core wire because gas is expensive. But my brother keeps saying that we cant weld aluminum with it I have heard of aluminium flux core wire but he still says it wont work. Dose the aluminum flux core wire work any good or is there something else we need to get?
iceng
iceng
Best Answer 5 years ago
Aluminum is welded with AC current and a covering gas to prevent Al2O3 oxidation which hurts the weld strength.
If your flux core can displace the oxygen around your weld give it a try. It will only hurt the scrap aluminum.
Dalen Brewer
Dalen Brewer
Answer 5 years ago
Could it hurt the welder at all?
iceng
iceng
Answer 5 years ago
"It will only hurt the scrap aluminum."
Downunder35m
Downunder35m
Answer 5 years ago
The welder does not care what it is welding.
But for the solfter aluminium wire you might have to adjust to feeder.
The only flux core wire for aluminium I have seen is for soldering, not for welding though.
If you want to try the welding get a roll of aluminium welding wire and a disposable Argon gas bottle, the small ones are quite cheap.
You will need a fair amount of practice round to get the settings on the welder correct and to create a good weld.
rickharris
rickharris
Answer 5 years ago
IF you can get cores wire for aluminium then you can use it. I haven't seen any though and I endorse everything said above. Despite efforts to solder aluminium several times I always end up using a mechanical attachment - pop rivets work well.
AppleS8
AppleS8
2 years ago
Good day.
Can be Dc welding machine for alluminum?and if not what welding machime should I buy?.
Thank you
evanengineer99
evanengineer99
Reply 1 year ago
It depends on what machine you are talking about. TIG welders have to have an AC to weld aluminum properly so most dc welders wont work. It is near impossible to stick weld aluminum so you are better off either soldering the aluminum with a propane torch and flux or buying an expensive high grade AC TIG/Stick machine
evanengineer99
evanengineer99
1 year ago
Aluminum is such an exotic metal and most flux wires cannot weld it. It depends on the machine as not every mig welder is geared to weld aluminum. A better alternative would be to braze/solder aluminum together with a cheap propane torch. In order to do aluminum welding, gas is the best way and you will often need a spoolgun.
AppleS8
AppleS8
2 years ago
Good day
I have quetion
I hope anyone answer me.
Can be Dc welding machine for alluminum??.
And if not what welding machine i should buy.
Downunder35m
Downunder35m
5 years ago
Welding aluminium can be a pain in the butt if you don't have the right welder and use Argon gas.
For small repairs I actually prefer soldering the aluminium.
Not recommended for structual work or bigger repairs, but good for cracks, holes and small things.
In any case clean tools made from stainless steel are a must have - I strongly recommend to only use dedicated tools that will get no use on other materials!
Just a quickie for soldering:
You need;
Sharp knife (stainless steel)
Stainless stell wire brush
Stainless steel scraping pin - I use a thick stainless steel wire, one side ground flat like a screwdriver, the other like a needle
Plumbing solder - the thick kind with no flux in
Acetone to remove any grease and oil before starting
(small parts I dump into a solution of sodium hydroxide to remove the oxide layer)
Blow torch or big soldering iron for smaller parts
How to;
Clean the aluminium from dirt and grease.
Scrape the soldering area with the knife to remove the oxide and some material so it can be replaced by the solder.
Use the wire brush after to smooth the surface a bit or to clean hard to reach areas - wherever you need solder the alu must be free of the oxide layer.
Fix the two parts together so they can not move and try to make sure there is no gap between them, this helps a lot.
Heat the aluminium, either with the soldering iron or blow torch from the other side (you don't want the flame on the area to solder until you actually have some solder sticking to it.).
Once the parts reach a good heat (check if the solder starts melting on the alu) use the wire brush or scraper to keep the oxide layer from building - this is an ongoing process.
Scratch the solder over the aluminium, you want to the heat so the solder needs a moment to get soft, you literally scratch the solder off the solder stick onto the alu.
If the solder won't stick in some areas use the scraper and the solder around the area to scratch through the oxide, you will see it is correct when the solder starts to form a "film" on the aluminium insted of just sitting on top of it.
Once it looks like you covered the entire alu surface (where you need it) with a thin layer of solder it is time to fill the crack, simply add more solder by scraping it in.
It might be necessary to use the scraper or wire brush a few times until you really get the solder where you need it to stick.
Add enough solder it goes slightly over the surrounding aluminium.
If you think it looks good leave it otherwise cut the excess solder off or file it down, once polished you won't even see the repair area.
discostu956
discostu956
Answer 5 years ago
When you say plumbing solder, your talking standard lead (or lead free equivalent) that's used on copper and steel etc?
Flux hurts the process does it?
iceng
iceng
Answer 5 years ago
Impressive
