263Views5Replies
Author Options:
Can I wire 2 LED strip lights with separate switches onto my PC? Answered
Hi.  I installed 2 LED strips in parallel to a molex connector (Pic A) in my PC case.  Now, I would like to add separate switches for each strip. Can I do it as depicted in Pic B?
Is it possible and safe to supply them with only 5v?
*The LED strips are both 12v 3528 LEDs (blue & white).  However, I do not know the current nor power requirements of the strips.
Thank you.
Downunder35m
Downunder35m
Best Answer 4 years ago
Should be no problem as the 12V rail should be with enough power reserve.
The only thing I would not use are these dimmers as they often cause massive interferenve on the input line.
So you should be fine unless you use a few meters each.
hopefool
hopefool
Answer 4 years ago
What about supplying the 12v LEDs with only 5v, would that be okay?
Downunder35m
Downunder35m
Answer 4 years ago
I doubt it, if you are lucky you get a slight glow but not more.
9V should be the lower limit.
iceng
iceng
Answer 4 years ago
+1
Sorry, I take too long to copy...
iceng
iceng
4 years ago
No problem of damage if that worries you..
On +5VDC they will probably not even glow.
White, blue and UV LEDs use more voltage then most and if the strip uses two or three in series per section their combined overcome voltage is more then +5V = NoGlow...
hopefool
hopefool
Answer 4 years ago
Thank you.
