1596Views16Replies
Author Options:
Can Painted or Stained 2x6 boards be run through a planer? Answered
I have 2x6 Painted/Stained outdoor stair treads that are a little rough and peeling from the sun. Can I run them through my planer without damaging the cutter? I'm hoping to get a nice smooth, clean surface to stain without trying to sand everything. Thanks for your help.
Tags:planer
mpilchfamily
mpilchfamily
Best Answer 8 years ago
I belt or orbital sander with 60 grit paper will make quick work of that. Then move to 150 to smooth it all out for painting.
jonallyn
jonallyn
Answer 8 years ago
Thanks everyone. I went with the belt sander. Couldn't get the 60 so I went with 50. That got the cupping out and stripped off the paint in no time. I followed it up with 80 grit to take out some random marks and then 120 grit on a palm sander. Used an acrylic stain that went on beautifully. I will need a second coat but they are looking great. Thanks again.
steveastrouk
steveastrouk
8 years ago
They'll play havoc with the blades, because there'll be embedded grit in the surfaces.
Kiteman
Kiteman
Answer 8 years ago
I've seen much raggier timber go through a thicknesser without problem.
steveastrouk
steveastrouk
Answer 8 years ago
Your thicknesser. or someone else's......
I've done plenty of of raggy LOOKING stuff, only I can guarantee embedded stones and all sorts of things in steps.
Kiteman
Kiteman
Answer 8 years ago
School's.
We, er, recycled a bunch of pallets and old benches into useable timber.
frollard
frollard
Answer 8 years ago
+1
It'll work but the blades will dull very fast, with any luck you can get access to a sanding 'planer' to take the top layer off.
steveastrouk
steveastrouk
Answer 8 years ago
I'd've suggested TCT blades, but they also wouldn't take that kind of abuse.
frollard
frollard
Answer 8 years ago
perhaps a pressure washer could get rid of a lot of the abuse...
