862Views9Replies
Author Options:
Can any one identify this component? Answered
I find it a lot on sound enabled electronics PCBs. It is this black circle on the board.
karnuvap
karnuvap
Best Answer 11 years ago
What this is is COB - which stands for Chip-On-Board. Instead of buying the packaged chip (black oblong with silver legs) they buy just the bare silicon chip which has been specially prepared with solder blobs on the contacts on its surface. Then they mount this bare silicon directly to the PCB by positioning it over the pads and warming it up so that the solder blobs melt anf the chip is fixed to the pcb. This is sometimes called 'flip-chip' because the chip is mounted face-down onto the pcb. But the silicon is fragile and so they cover it with a blob of black goo to protect it. This method is used because it is compact and very cheap - so it can be used in greetings cards for example. But it is also used on the back of LCDs for their driver chips too.
seandogue
seandogue
11 years ago
zem, I was able to auto correct for lighting, and play a couple of games to improve the resolution, but it's still kinda blurry. (using a webcam?) anyway, it looks like they may have covered an ic with a blob of epoxy. I originally though tit might be a speaker, and it may still be, (or the underside of one) but from the pic it looks like some from of obscuration trick, either to avoid someone finding they've impinged on someone else's copyrights or to avoid competition getting hold of a part number for something that can't be copyrighted it could also be the underside of a component that needed to be mounted using epoxy for vibration isolation...not sure Pic of the other side please.
Zem
Zem
Answer 11 years ago
Hey, sorry the quality is not very good, cell phone pictures... Here is the picture of the other side, the resistor on top at the very edge is right over the black blob.
seandogue
seandogue
Answer 11 years ago
I think that either karnuvap and/or Jayefuu accurately answered your question already.
Zem
Zem
Answer 11 years ago
Okay!
lemonie
lemonie
11 years ago
I agree with the others - the black blob is in effect a case for the chip underneath. It's a microprocessor / memory chip. L
Jayefuu
Jayefuu
11 years ago
Underneath it is a tiny microchip with some software embedded in it. The actual black bit is just some plastic to protect it. (I think)
seandogue
seandogue
Answer 11 years ago
Very good!...might quite well be an Eprom. black goo to prevent accidental wipe of IC contents thru the erase window
Zem
Zem
Answer 11 years ago
Ah! Thank you guys.
