92Views5Replies
Author Options:
Can any one tell me how to replace a laser diode 13T/15R with Led ? Answered
what ratings are necessary for matching the requirement of transmission and reception..
Which type of led may be used?
Tags:LED
Alia Bakhsh
Alia Bakhsh
6 years ago
like in fiber optic cable we are using laser diode we can also use LED ..so which type of LED will match with the ratings of 13T/15R laser diode?
steveastrouk
steveastrouk
Answer 6 years ago
If you want acceptable coupling you'll need to match the NA of the fibre and the source. A laser has an NA close to that of the fibre, an LED does not. You will need additional optics.
iceng
iceng
6 years ago
Look up the dominant laser wavelength ie frequency and buy an LED with the same wavelength.
mpilchfamily
mpilchfamily
6 years ago
A Laser Diode and an LED are 2 totally different things. You cannot replace one with the other.
Alia Bakhsh
Alia Bakhsh
Answer 6 years ago
but there might be some technique?
mpilchfamily
mpilchfamily
Answer 6 years ago
What kind of application is this being used on? If it's for fiberoptics then it all depends on the receiver being used and what specs it is looing for from the light being transmitted through the cable.
