367Views2Replies
Author Options:
Can anyone explain why this batch file doesn't work correctly? Answered
this is the code: @echo off
:Side
ping localhost -n 2
:Main
cls
color Fc
echo  Rock, Paper, Scissors!
pause
echo How to play:
pause
echo Type either Rock, Paper or Scissors in the bar and press enter, your opponents
choice will show, and repeat!
pause
:Start
cls
set /p %input0%= Enter your choice here :
:ans
set /a ran=%random%
if /i %ran% GTR 7 goto :1
if /i %ran% LSS 7 goto :2
if /i %ran% LSS 4 goto :3
:1
if %input0%== Scissors
echo Your opponent chose Rock, Rock beats Scissors, you lost!
else
echo You Win!
pause
goto Start
:2
if %input0%== Rock
echo You Win!
else
echo Your opponent chose Paper, Sorry you lose!
pause
goto Start
:3
if %input0%== Paper
echo You Win!
else
echo Your opponent chose Scissors, Sorry you lose!
pause
goto Start
can someone explain why this doesn't work?
Quercus austrina
Quercus austrina
Best Answer 5 years ago
Another thing to do is move the "LSS 4 " above the "LSS 7". As it stands, you will never go to :3 because any number less than 7, including those less than 4, will go to :2, completely skipping :3.
Qa.
zomarea225
zomarea225
Answer 5 years ago
thankyou!
Downunder35m
Downunder35m
5 years ago
What do you mean "does not work"?
If you get weird errors I suggest to save in a ANSI format, apart from that the LSS and GTR commands are used for numbers, not words.
So you would have to assign a number the choice entered.
You generate a random number between 0 and 32767 to compare with a text input - like comparing apples to bricks ;)
petercd
petercd
5 years ago
You need another echo in front of choice will show, and repeat! or else it sees choice as a command.
Afterthat it gives a syntax command error, maybe you've left out some subs.
zomarea225
zomarea225
5 years ago
thanks for the help!
