772Views8Replies
Can anyone help identify two components?
This board is from an old Barbie piano I'm fixing for my aunt. In order to further troubleshoot it I need to figure out what these are. They are indicated by the two arrows.
Edit: Just wanted to add that I have attempted to google the codes on the two and it came up with nothing.
Best Answer 7 years ago
They are sip resistors all wired to a single leftmost or rightmost pin
Saves a lot of room if they are the same value. See the pic.
A
Answer 7 years ago
+1. There is usually a dot on the common end.
7 years ago
Look to me like zip resistors
Answer 7 years ago
SIP =>> Single Inline Package a Resistor Array that may add zip to your life..
7 years ago
FYI these are probably precision parts, and are used in generating the various tones.
7 years ago
The black is resistors the yellow is capacitors.
Photograph or tell me exactly what is on them and I can tell you the values.
Answer 7 years ago
I have black, blue and the yellow.
Boy do they hurt when accidentally stuck through the skin as in "FLY"
A :-)
Answer 7 years ago
Been there.
The markings tell you the value they have a code much like surface mount resistors and capacitors. 102 is 1 k ohm and 101K is 100pF +-10%
