Can anyone tell me how to wire this motor (from an AC)?
I wired an AC in my room to the central heating unit, but the electronics inside were destroyed(only the motor worked). I've wired the motor to a dimmer switch (and of course the cap it had) but there are still 3 (or so) wires left. The way I've wired it i can control the rpm to a certain point but then it starts making a weird humming noise. From what i can('t) tell this thing is frequency controlled for lower rpm (or at least that's what a friend told me)
I've also wired a temperature relay in series to the dimmer switch so it stops when it starts blowing cold air.
So, i was wondering what am I supposed to do with those extra wires, it doesn't say anywhere what they are/do I don't know if you can see it clearly in the pic. the motor runs on 220V (well I don't know what the voltage is after the dimmer.) It says 220V on the motor but when I run it on that voltage for about 20-30 minutes it gets REALLY hot. (and the voltage in my room is really low, about 200-210 V sometimes it goes up to 220V)
So, the question is have i wired it correctly or should i make some sort of controller for it.
Thanks in advance!
(Also this thing heats up the room in no time, when the input temperature is about 30-40C)
9 years ago
LOOK similar to my motor on Wall evap split system
large plug power has 3 wires red white black for power
L to white
N to red
and a 4.7 capacitor between black and white
the other 3 possibly 5 Vdc pulses feedback to the mpu 5V + minus and pulses
this may help ?
Answer 9 years ago
The motor looks exactly the same. But mine is rated 12W(it's blurry on the pic), the cap is 2uF and is connected to Red and White, power goes to Black and White.
So, this either means I've wired it wrong or the guy that gave it to me wired it wrong.
9 years ago
How many wires are on the motor ?
Steve
Answer 9 years ago
There are 6 wires :
That's what it says on the side
1-Brown-------] Electronic Control
2-Green--------] P.C. 1,2,3 are E.L. Control. PC Board
3-Yellow-------] Board
1-White
2-Red -----Cap----|
3-Black --------------|
9 years ago
First the HOT motor, your dimmer may not be full wave or is unbalanced feeding
DC to your AC motor. How mane wires actually come / go to the motor.
You could be running a start coil in the motor ( used to Only start the rotation) .
Answer 9 years ago
Forgot, Six come out and i'm only using 3 (2 are power and the third is the Cap)
The other 3 are for some kind of control (on the block diagram they are Electronic Control P.C. Board)
Answer 9 years ago
Actually I just replaced the dimmer (motor is cold now), before it used one from a drill and i guess there was the problem. I think this dimmer is full wave tho.
Also power is connected to Black and White (i think), and i had no idea these things have start coils.
