15206Views20Replies
Author Options:
Can i get a replacement of this transistor ? Answered
Hello,
i was just messing with circuits and i found this one above in the image i really want to make this but i don't have a BF494 transistor so my question is : Is it possible to replace this transistor with any other transistor if possible please name all possible replacement you know!
steveastrouk
steveastrouk
Best Answer 7 years ago
Check the Ft of the BF494 (200Mhz) and match it with what you can get locally. The BT494 is a pretty damned fast little transistor, so be careful.
ubdussamad
ubdussamad
Answer 7 years ago
Thanks for your help but tell me what Ft stands for ? (Beause i am not well known to electronics!)
steveastrouk
steveastrouk
Answer 7 years ago
Ft stands for "transition frequency", and is a measure of the kind of frequencies you can expect the transistor to work at
Its a parameter on the datasheet for the transistor. Look for "High frequency" transistors.
The BC109 might be OK for you here.
Gooda1999
Gooda1999
1 year ago
What is the Replacement of transistor BF494?
ubdussamad
ubdussamad
Reply 1 year ago
Read steve's answer, in short BC109 could work fine as steve said.
OGF2
OGF2
2 years ago
I found it difficult to find transistor BF494. Which transistor or component can I use to replace it. Please help me out
ajay20060
ajay20060
4 years ago
if i have bc 107 transistor which have different characterstic of bf494 so what change we have eo in circuit
vikasgurlinka
vikasgurlinka
5 years ago
2N3904 or 2N2222 might do you but a 2N3707 is identical to a BF494.
You can get the datasheets here:
http://www.maxim4u.com/
You can get the datasheets and the parts for less than Radio Shack here:
http://ca.mouser.com/Electronic-Components/
Mouser has a great search filter that enables you to put the parameters of a component in and it will tell you all the parts that fit.
stoobers
stoobers
5 years ago
This looks like an am receiver with fixed regeneration. if so you can use any npn "popcorn" transistor. Common examples include 2n2222 or 2n3904.
EiadS
EiadS
5 years ago
doest tl494 replace bf494
denmarkmediana.
denmarkmediana.
5 years ago
hi, what is the replacement for B1453 transistor
ubdussamad
ubdussamad
Answer 5 years ago
2SC5880 from farnell will do your job. Because you need a low Ft , so i am guessing it is for some high voltage switching (60).
farhan.ali.92351
farhan.ali.92351
6 years ago
Hello , i dont have a 2N2222, so is it possibloe to replace this transistor with any other transistor is possible
Quantum-Physics
Quantum-Physics
Answer 6 years ago
Yes, for general purpose circuit BC 547 or BC 548 or bc 557 work pretty same !
Though you can show me the circuit i will tell you what to do!
carl winter
carl winter
Answer 6 years ago
I use BC 457 AND 458 -- NPN --- virtually the same
BC transistors are quite common ---
2n2222 have slight voltage difference ---
look up in your tables ---its all there
regards---
farhan.ali.92351
farhan.ali.92351
6 years ago
iceng
iceng
7 years ago
The physical placement of the RF ( Radio Frequency ) components is CRITICAL
So is the length  of the antenna and the diameter of the four turns..
If you have a pic of this working Follow it exactly.
A
