118Views7Replies
Author Options:
Can i power a TV without Remote? Answered
I have an old TV and i cant power him on without remote. Why? i dont know. I called an specialist, but he said that to. I know something about electronics, so can i do something in the IR bloc? like make a bridge betwen leds legs? i dont know, this is an idea i have, but im affraid that it blows the IR bloc. i had another idea, to change the entire IR bloc,  but i cant find one and i dont have the knowledge to do that. so! i put a question here, can i do something or not??
Tags:tvirled
Vyger
Vyger
6 years ago
I had one that had the power button get pushed in. On many of these types of things they use hot melt glue and it sometimes comes unstuck. So open the case and see if the button has come loose. All you might need to do is glue it back correctly.
If you want to use a remote do like the others say and get a universal one that can be programed for your unit.
danyelo
danyelo
Answer 6 years ago
the power button it lightup the stand-by led. but if i try to power it on to watch, i can. i press every button but nothing. and the specialist tell me that only with Custom IR remote, and it cost more than the tv :))) this is why i ask here, the specialists from the world. can i make a bridge betwen some pins to start it up??
Diaphane
Diaphane
Answer 6 years ago
Maybe he was just trying to sell you a new tv...or an expensive remote...
Is your remote broken? you can test that with a digital camera. Remotes work with infra red light and the human eye can't see that. But if you look at the light with a digital camera you should be able to see it light up when you push a button on the remote.
If your remote works then it could be a problem inside the tv.
If the remote is broken you should try it with a universal remote, they are cheap.
FarmerKJS
FarmerKJS
6 years ago
You could TRY using a tv-be-gone to power it on and off
danyelo
danyelo
Answer 6 years ago
what is tv-be-gone?
FarmerKJS
FarmerKJS
Answer 6 years ago
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
mpilchfamily
mpilchfamily
6 years ago
Get a universal remote and program it for the brand of the TV and your all set.
More can be done but requires expencive test equipment and more knowledge then you currently have.
