358Views5Replies
Author Options:
Can i use 3 leds (20-30 mAh, 2,8-3,4 V) with a 3 volt battery?Do I need resistors? Answered
Tags:Led
steveastrouk
steveastrouk
11 years ago
Like L says, they'll light, but they won't get 20-30mA flowing through them, so they won't be full brightness.
Popstickal
Popstickal
Answer 11 years ago
Is it smarter to get 2*3V battery = 6V and then use a resistor to limit the current to 3,2V and then use 3 led´s?
Would I get full brightness then?
And can you say witch kind of resistor I should be using?
Is it smarter to limit the current to 3V instead of 3,2, then the led´s should survive longer.But I guess they wont be as bright.
I want to build a flashlight white these 3 led´s and make them bright, can you help?
steveastrouk
steveastrouk
Answer 11 years ago
You don't limit the volts, you limit the current. The volts take care of themselves. Do these LEDs say they have a 3.2..3.6 volt forward drop ? Yes, you'd be better with a higher voltage and a resistor - you'll get full brightness that way.
Steve
Popstickal
Popstickal
11 years ago
But how do I get 20-30mA flowing between them?
Okey I have new led´s.
3 led´s with ( 3,2~ 3,6).
If a use a 6 V battery and use a 150 ohm resistor I would get 3,4 V.
Is it , good?
Would it be full bright for a flashlight?
lemonie
lemonie
11 years ago
They'll be 20-30mA (no H).
Above 3V I wouldn't think so, 2.8 to 3 you should be OK, and without a resistor (unless these are expensive and you don't want to take risks?)
L
