431Views2Replies
Author Options:
Can someone advise how to measure output from a bike generator/dynamo ? Answered
This is the type that clamps onto the seat stay and is meant to rub the tire for the generating action. It's labeled 12V, 6W, Made in Japan. Two terminals, H and T. I've hooked it up to a meter and the only setting that gives me any sort of reading is AC volts with either H or T and to what I assume would be chassis ground. That gives me between 3.7 and 4 volts when I spin the unit with a cordless drill. Is this thing functional or not? And what would be proper wiring connections for it? Many thanks!
Dr.Bill
Dr.Bill
11 years ago
they produce ac. hook-up the meter and go for a ride.
NachoMahma
NachoMahma
11 years ago
. I'm guessing that H = headlight and T = taillight. They may be connected together internally.
. The drill may not be spinning the generator as fast as a tire will.
. Find a 4-10 W @ 3-6 V bulb and see if you can make it light with the drill. Connect to H or T (shouldn't matter which) and the generator case (ground).
