413Views4Replies
Author Options:
Can someone help me make a low cost shower oppurtunity? Answered
Like the Zodi camping shower or Eccotemp? They seem real easy. Im just not that handy...Thanx!
Links to both:
Zodi: http://www.zodi.com/web-content/Consumer/zodihottaptravelshower.html
Eccotemp: http://www.productsthatsave.com/ptsl5.html
Ole bally
Best Answer 8 years ago
Out here in the African 'colonies'!! :) we take a 20 liter galvanised steel bucket, drill a 20mm hole in the bottom at center, take a 3/4" galv. nipple and using two flat nuts and some thread tape secure the nipple into the bottom of the bucket. take a 3/4 brass in line tap and with thread tape screw it onto the bottom of the nipple. Put yet anpother nipple underneath the tap and screw on a standard galv. steel shower rose and using some more thread tape screw it onto the bottom. A 3/4 bucket of hot water mixed with some cold will give you a good long hot shower. Heat water in a separate bucket or steel container over a fire! so yr materials are: 1 x steel galvanised bucket. 2 galvanised 3/4" nipples. 1 in line 3/4" tap (fawcett!!) 2 flat nuts ( one for either side of the bucket bottom.) Of course you could use silicon to seal with too. a steel shower rose. Use a length of rope to pull it up into yr tree - oh and build a shower curtain!! - and you have an african safari shower! Use the rubber floor mats from yr car to stand on! put the whole deal up on a slight incline to allow yr shower water to run off!
landline
10 years ago
I'm going to be whipping one up for a campout this summer, that will use a tank, a turkey cooker, and a 5 gallon bucket. I'll keep you posted. Nag me occasionally. I'll try to remember to take pictures.
kimxtc
10 years ago
Thanx for the idea but unfortunately we don't have much sun here in Seattle. :( Anybody else? C'mon I've seen some geniouses on this site.
DELETED_GuardianFox
10 years ago
1. Double up two regular garbage bags or use just one heavy duty one. Choose a dark color. 2. Add a few gallons of water. (Say roughly 1/3 the capacity marked on the box) 3. Tie off the bags. 4. Leave in the sun for 6-8 hours. 5. Hang from a tree, just above your head. How to use: 6. Poke a small hole or two near the corner of the bag with a twig or whatever you have. 7. Get wet. 8. Tie off the corner with the hole. 9. Lather up and scrub. 10. Poke a couple new holes. 11. Rinse off.
