105Views1Replies
Author Options:
Can someone help me wire this? Answered
I took apart a speaker and I want to lengthen the wire and add a bluetooth dongle. I already took apart the dongle and the parts appear to fit correctly. The biggest problem I see is the different size of the wire I would like to use as an extension.
Josehf Murchison
Josehf Murchison
Best Answer 7 years ago
As long as the wattage matches the wire size is not important, (current and voltage). Although I would replace the wire from circuit board to circuit board to speaker just for a more reliable connection.
If the wattage does not match you may need a buffer circuit between the two to match the output to the input.
