273Views9Replies
Author Options:
Can someone help me write a code for an Arduino to power a servo? Answered
Hey I'm looking at doing a project and I need 2 servos to sweep their arms alternately from about 140  to 180 degrees and use a push button to turn it on and off. Can someone please help me with this? Thanks!
Tags:arduino
MichaelP24
4 years ago
looking for .....help........ on code for arduino .......................... help..............
MichaelP24
4 years ago
RalucaA
5 years ago
Can someone help me write a code for Arduino Uno to power a ESC Swordfish Pro? I am using a wii nunckuck as an input for the ardunino, pins 3V/gnd, 4 and 5 and for the output pin 9 that goes to the ESC. It needs to move a longboard, forward, backward and laterlals. Thank you very much!
RalucaA
5 years ago
robo10302
5 years ago
how much of a delay do you want between each time the servo stops and the other servo starts?
TELLERMAN4robo10302
Answer 5 years ago
Hey the sketch didn't work the servo plugged into 9 was unable to complete it's full rotation. I hate to ask again, but could you write another code but only for one servo to move from about 180 to 160 with no delay between movements? Thanks for the help by the way.
robo10302TELLERMAN4
Answer 5 years ago
Sure no prob here :-
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 160; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=160; pos-=1) // goes from 180 degrees to 0 degrees
tell me if it works
TELLERMAN4robo10302
Answer 5 years ago
Well I think the code is what i want but the angles are wrong how do i change the angle in the code for the servo to move?
robo10302TELLERMAN4
Answer 5 years ago
Ok thats not a problem you just need to change the number values in these sentences. for(pos = 140; pos < 180; pos += 1) change the 140 and 180 to the angle u want the numbers refer to the angles. So this for(pos = 140; pos < 180; pos += 1) says take the servo to angle of 140 and then increment it to 180.
Hope this helps :) by the way what are you making?
TELLERMAN4robo10302
Answer 5 years ago
Yea that helps tremendously thank you I got the code to work the way I needed it too thanks again and I'm making a paintball gun sentry turret and I needed something to pull the trigger besides my finger obviously and I had a couple servos around and so I'm here haha thanks again
robo10302TELLERMAN4
Answer 5 years ago
Happy to hear that would love to see some photos once your done.
Good luck on that :)
robo10302
5 years ago
hope this helps
// Sweep
#include <Servo.h>
Servo myservo1; // a maximum of eight servo objects can be created
void setup()
myservo.attach(9);
myservo1.attach(10); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 140; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
for(pos = 180; pos>=140; pos-=1) // goes from 180 degrees to 0 degrees
delay(1000);
delay(15);
delay(1000); // waits 15ms for the servo to reach the position
