107Views8Replies
Author Options:
Can someone help with my anti auto theft arduino device? I am trying to use a reed switch and a relay. Answered
     I am trying to build a device for my engineering project which is a anti theft device for cargo trucks in third world countries. Since cargo stealing is very common truckers already use satellite tracking. The device works in the following way, in an attempt to steal the truck a thieve tries to breach into the truck"s electrics to disable the satellite tracking, but the reed switch detects the breach and the arduino stops feeding power to a relay which is connected truck's electronic fuel injection system, thus making the truck's engine to stop and consequently immobilizing the cargo.
     The system uses a 4x4 matrix keypad, one relay(I might add more) and one reed switch but I am planning to use two. When the sensor is breached the arduino is supposed to cut power to the relay. If the correct password in entered in the keypad the system turns the relays on until the sensor is breached again, if the wrong password is entered it remains locked.
     I managed to find a password code a guy shared which worked with the keypad and the relays, but when I try to add a if statement to lock when the sensor is breached it simply does not work.
Thanks in advance for the help.
#include<Keypad.h>
int Relay1 = 13;
int Relay2 = 12;
int greenPin = 11;
int Sensor1 = A1;
int Sensor1Valor = analogRead(Sensor1);
int position = 0;
const char * password = "123";
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = { 8, 7, 6, 9 };
byte colPins[COLS] = { 5, 4, 3, 2 };
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup()
Serial.begin(9600);
pinMode(Sensor1, INPUT);
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(greenPin, OUTPUT);
digitalWrite(Relay1, HIGH);
digitalWrite(Relay2, HIGH);
setLocked(false);
void loop()
char key = keypad.getKey();
Serial.println(analogRead(A1));
if (key == '*' || key == '#')
position = 0;
setLocked(true);
if (key == password[position])
position ++;
if (position == 3)
setLocked(false);
if (analogRead(A1) > 300);
setLocked(true);
void setLocked(int locked)
if (locked)
digitalWrite(greenPin, LOW);
digitalWrite(Relay1, LOW);
digitalWrite(Relay2, LOW);
else
digitalWrite(greenPin, HIGH);
Vyger
Vyger
3 years ago
You might think about going with a trunk monkey instead.
steveastrouk
steveastrouk
3 years ago
What is the analog read for ?
LuccaL1
LuccaL1
Answer 3 years ago
it is for the reed switch
steveastrouk
steveastrouk
Answer 3 years ago
Make sure you have either an external pullup resistor or you turn on the ones in the Arduino. My preference is the external resistor
LuccaL1
LuccaL1
Answer 3 years ago
oh thank you, i did not know I had to use resistors with this sensor, why is that?
steveastrouk
steveastrouk
Answer 3 years ago
because for the instant they are transitioning, the voltage on the input pin is not defined.
steveastrouk
steveastrouk
Answer 3 years ago
Switches are generally treated as digital input devices - connect to +5 = on, gnd = off.
LuccaL1
LuccaL1
Answer 3 years ago
I thought the same thing but for some reason when I tried to use it as a digital sensor it only showed 0's completely ignoring if it was closed or opened. When I tried as an analog sensor it gave me values I could work with, usually between 0 and 500.
