SIM800A Quad Band GSM/GPRS Module with RS232 Interface is a complete Quad-band GSM/GPRS solution in a LGA(Land grid array) type which can be embedded in the customer applications. SIM800A disney hub supports Quad-band 850/900/1800/1900 MHz, it can transmit Voice, SMS and data information with low power consumption. With tiny size of 100 x 53 x 15 mm, it can fit into slim and compact demands of customer design. Featuring and Embedded AT, it allows total cost savings and fast time-to-market for customer applications.
Sometimes after powering up the module, after getting registered on the network, the network LED starts flashing as if there is no network found, and also I cannot make any calls or sms during these time.
But after restarting the module, everything works fine.
I have used 12V 7A battery for powering the module.
I am not able to find the problem, please guide me.
The SIM900 is a complete Quad-band GSM/GPRS solution in a SMT module which can be embedded in the customer applications. Featuring an industry-standard interface, the SIM900 delivers GSM/GPRS 850/900/1800/1900MHz performance for voice, SMS, Data, and Fax in a small form factor and (https://roadrunneremail.org/) with low power consumption. With a tiny configuration of 24mm x 24mm x 3 mm, SIM900 can fit almost all the space requirements in your M2M application, especially for slim and compact demand of design.
8 months ago
1 year ago
1 year ago
I google "SIM800 TTL" and basically the first hit:
1 year ago
The
demand of design.
