1536Views7Replies
Author Options:
Can we join two metal surfaces of Stainless Steel & Mild Steel without welding them? Answered
My question is that is there any gum/paste/glue to fix the both the joints. My application is that we want to join the Mild Steel enclosure with Stainless Steel Flange without any gap between the two joining surfaces. Our thickness of the metal is the Mild steel is of 1.2 mm thickness & 1.5 mm of Stainless steel. Pls suggest your valid answers.
Tags:tag
Gopi2012
Gopi2012
9 years ago
Thanx for your comments. I would request you to suggest what type of putty / ahdesive or the glue has to be used for joining the two surfaces MS Body & SS Flange. Waiting for your valuable answers
steveastrouk
steveastrouk
Answer 9 years ago
AKA "Gramophoned" ? With a gasket ?
Steve
rickharris
rickharris
9 years ago
I would pop rivet and seal the joint before with silicone if I wanted to be a real seal.
steveastrouk
steveastrouk
9 years ago
Either rivets, or braze would work well
frollard
frollard
9 years ago
a 2-part epoxy like jb weld or other putty adhesive would get the job done. It won't be the strongest thing in the world but not bad. It will help mechanical strength if the 2 parts interlock before being glued together.
