Can you Please Help with Arduino Code?
I was wondering if you could help me with the code i have. Its basic and my knowledge of coding if very limited.
Im upgrading my fume extractor and in the spirit of keeping up with the 21st century, i want to dump the old throw switch and implement capSense. The code i have works brilliant with but its for 1 switch but i need 2 and don't know how to do it
this is the code(read below code for more):
#include <CapSense.h>
// 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, foil
CapSense cs_4_2 = CapSense(4,2);
const int ledPin1 = 13;
void setup()
cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
Serial.begin(9600);
void loop() {
static boolean lastSensorHit = false;
static boolean LEDvalue = LOW;
bool sensorHit = cs_4_2.capSense(30) > 1100;
if (sensorHit && !lastSensorHit) // Now true, was false
LEDvalue = !LEDvalue; // Toggle the LED
digitalWrite(ledPin1, LEDvalue);
lastSensorHit = sensorHit;
delay(100);
What I'd like to do is, have 1st capSense give out 2 outputs say 2 Led's and stay on just like in the code and the 2nd capSense move a servo 45 degrees delay .5 second then give out 1 output i.e an Led aand stay on, just like capsense 1.
Thank you in advance everyone.
