2396Views8Replies
Author Options:
Can you build a very small fm/or am receiver that only receives a single frequency? Answered
Tags:radio
Smokedasphalt
Smokedasphalt
Best Answer 11 years ago
Almost all FM/AM receiversuse a variable capacitor to adjust frequencies. If you use a Capacitor of a fixed value, then you will be able to receive only a fixed frequency (depending on the value of the capacitor used.)
ethosrot
ethosrot
Answer 11 years ago
Smokedasphalt is correct in this. Though you may have a difficult time finding capacitors with arbitrary values, unless you're familiar with series-parallel capacitor calculations. A more practical solution might be to include the variable capacitor anyways, and tune it before you put it in a project box (or whatever have you). Epoxy or hot glue the top of the dial so it doesn't shift on its own, and just leave it inside the case. That way nobody can change it from whatever you've set it to.
Smokedasphalt
Smokedasphalt
Answer 11 years ago
Yeah, as ACProdigy says, you can hot glue it. Or rather, tune it and keep it inside the case so that nobody changes it. This will eliminate the work of searching for a capacitor of a particular value and also, you can always change the frequency if the need arises!
ethosrot
ethosrot
Answer 11 years ago
Well said mate.
rickharris
rickharris
11 years ago
Yes there are lots of kits for building spy/surveillance radios It is easier to buy one of them.
extrordinary1
extrordinary1
Answer 11 years ago
True, but if I was using one of those, I would be using it for a hidden bug in an ink pen I left where I wanted it, or conceled as a button, like our FBI uses. Short ranged to about 700 ft. Needs no batteries, as it uses the power of a local radio station for it's power source for the bug. Learn how to do in second phase electronics engineering school.
