5948Views4Replies
Author Options:
Can you hook up a propane tank in place of natural gas hookup? Answered
For example, could you you connect a propane tank to something like this: http://bit.ly/fJG9VI It's a natural gas oven.
Tags:kitchen
Re-design
Re-design
10 years ago
No.
I think the fittings are different to prevent this.
You can probably get a kit of parts to turn this stove into a propane burning stove.
The problem is that nat gas and propane burn differently and the regulator and other parts are specific to the gas to be burned.
NachoMahma
NachoMahma
Answer 10 years ago
.  +1. Not compatible, but conversion kits are available. Along with the fittings being different, you have to change out the orifice(s) (propane has a higher BTU content) and possibly the whole burner assembly.
steveastrouk
steveastrouk
Answer 10 years ago
It burns at a different speed, so the orifice size changes
frollard
frollard
Answer 10 years ago
you "could" but it would asplode or not ignite :D
I do believe propane to be more potent, and usually at higher pressure (liquified) needing a much smaller pinhole regulator.
Natural gas, primarily Methane = C1H4
Propane = C3H8
Different ratio = different stoicheometric ratio to burn completely = different air mix = different everything.
