252Views8Replies
Can you make a pocket sized amp without distortion easily?
I would love to make a small pocket sized amp for my guitar, without distortion, but i cant get the signal strong enough. any help?
Best Answer 10 years ago
Look into Little Gem Amps.
10 years ago
. Most small amps are reasonably hi-fi* if you run them within specs. The problem is, in order to get twice the sound you have to pump out ten times the power. Ie, you need 50W to sound twice as loud as 500mW. The more watts, the more power supply you need - it quickly gets large and heavy by pocket standards.
. Use headphones or earbuds.
*Depending on just how high you want your hi-fi.
Answer 10 years ago
. Oops! That should be 5W to be twice as loud as 500mW, but you get the point.
Answer 10 years ago
YIKES!!! thats gonna be hard.
10 years ago
LM386 is a good audio IC for small projects
Answer 10 years ago
ok thanks, ill check it out!
10 years ago
Check out the Altoids tin amp. Tell the author to learn to use the macro on his/her camera while you're there. :)
Answer 10 years ago
Haha, that is a very true fact! thanks for the input, but i dont think that will help me, but we shall see! :p
